over heat only UP hill
turns out my welding job is not up to par. I could feel exhaust leaking through holes I didn't see. the muffler is on. I need to re-weld the opening in the cat where I pulled out the catalyst. Something I found out.... helps to reset the PCM after removing the cat. I was having some toruble with the truck stalling while coasting with the clutch in untill I reset the computer.
