Ram won't Idle... Intermittent problem
Old Mar 2, 2013 | 06:25 PM
  #21
gdstock's Avatar
gdstock
Disconnect battery first. Remove the throttle body so you can clean out the IAC port properly.
Old Mar 22, 2013 | 06:59 PM
  #22
mrau92me's Avatar
mrau92me
What purpose on disconnecting battery? Just to reset the PCM or to protect the IAC. I'm having a similar series of events. I did a diagnostic on mine, which involved turning the ign switch on, then I cleaned it with TB cleaner. Afterward, the CEL was on, but it went away after a couple driving cycles. I thought cleaning the IAC valve & the port did the trick (they were nasty), but the problem reared itself yesterday, but didn't today. I have to keep my foot on gas pedal at least until it warms up, then it's good. Should I just replace the IAC valve? could it be something electronically wrong with it? Also, I should mention that when I turn on the heater at anytime, I can hear a hissing from what sounds like to me might be a vacuum leak from inside the dash and when I turn the truck off, the hissing/high-pitched sound is still there and gradually fades away. Could this be related? I haven't had this truck long & this is first winter I've driven it, so some things I'm not sure about being normal or what.
Old Mar 23, 2013 | 09:49 AM
  #23
rott96's Avatar
rott96
You disconnect the battery otherwise the computer may not recognize the new part....so, even if you change a bad part with a new one it will still run the same.....until it cycles through....
Old Mar 25, 2013 | 11:24 AM
  #24
mrau92me's Avatar
mrau92me
Yeah, my check engine light came on after I cleaned the IAC valve and ran one simple diagnostic on it (I made sure the pintle would retract after turning key switch on). The CEL stayed on for about 2 or 3 driving cycles like I expected it would. But, as soon as the outside temperature dropped below 40degF again, the same problem appeared. From a cold start, it'll fire up but immediately quit. But, if I give it some throttle at start and give enough to keep the RPM around 1000 for about 30 seconds, it'll hold idle on its own after that.
