rebuilding 95 ram auto tranny
Old Apr 14, 2011 | 10:28 PM
92ram150le's Avatar
92ram150le
Question rebuilding 95 ram auto tranny
1. what tranny is in a 2wd 95 ram 1500
2. (problem) it wont shift
3. where do i find rebuild kits for one
im a long time old iron guy i have no clue with these newer pos but for $200 i couldnt turn it down
Old Apr 14, 2011 | 10:31 PM
46RH trans.
Check fluid level. Make sure to check in Neutral. (doesn't read accurate in park)
Many Places. Good place to start, would be to read thru MonteC's transmission Corner in the FAQ section here. Also in the FAQ section, is J415's transmission thread, with helpful links for rebuilding.
Old Apr 14, 2011 | 11:04 PM
J415's Avatar
J415
https://www.wittrans.com/Schematic.a...sion=A518/A618
These guys were great to deal with. I got a 3 day turnaround on my orders.
Old Apr 14, 2011 | 11:07 PM
Gerehead8's Avatar
Gerehead8
Newer POS? Ill agree that these trannies are junk but it isn't all that new, The A518 is just an A727 with an OD unit attached. HeyYou is correct and the A518 you have is the 46RH so it has a governor no governor solenoid.
It is an easy rebuild if you know how to do the A727 as the entire front half is identical to the A727. It has a larger 2 piece valve body for the OD unit so more cleaning but nothing out of the ordinary. You can rebuild the OD unit yourself but you need to compress a large spring that holds the direct clutch. I just had a tranny shop rebuild my OD unit so I didn't have to mess with it and it cost me $75.
You can get a rebuild kit anywhere for the A518.
I suggest getting an ATSG manual.
Old Apr 15, 2011 | 01:23 AM
mike.97.2500's Avatar
mike.97.2500
x2 atsg manual
and iv gone trough transstar for many rebuild kits lately and i really like theyre kits
Old Apr 15, 2011 | 01:12 PM
92ram150le's Avatar
92ram150le
lucky i got quoted for $800 if i take it out and bring it to them
Old Apr 15, 2011 | 01:36 PM
Was that for the whole trans though?
Old Apr 15, 2011 | 05:14 PM
thexh20's Avatar
thexh20
Originally Posted by mike.97.2500
x2 atsg manual
did you add a newer super servo?
