Will a 3" leveling spacer level an OFF-ROAD 1500?
Since the OFF-ROAD Model is Lifted 2" All-around but still has has the nose dive, I want to level the truck, will a 3"spacer level the truck or do I need a 4" or even a 5"? Also, When putting the leveling spacer, will the STOCK OFF-ROAD Pitman arm still be OK to use?
So the off-road trucks come with a 2" spacer or just a longer coil spring? How is the offroad version lifted 2", which method?
Trending Topics
The off road package gains its lift from different coils and leafs, not extra blocks.
Adding a 2" spacer will level it off perfectly. The stock pitman arm, track bar and control arms will work, but they will be at there max. Dont try going any higher than a 2" spacer.
LAST QUESTION on this:
1. Is the 2" Leveling Spacer the same for 1500,2500, and 3500?
2. Are the shocks the same for 1500,2500,3500?
I am getting Rancho SHOCKS all around and is the application the same?
