Lift question
Old Apr 15, 2011 | 08:34 AM
green97's Avatar
green97
Default Lift question
I'm looking to get a 4.5 inch lift do I need differ drive shafts slip yoke eliminators or anything else other than the blocks, spacers, drop pitman and brakes lines?
I have a 97 sport 1500 4x4 I'm trying to run 35x12.50's
Old Apr 15, 2011 | 09:07 AM
You will also need longer control arms, so the front axle will be in the right spot when you are done. Getting a lift that comes with the longer arms is the hot ticket. (and I am referring to the ones that relocate the rear mounting bracket for the control arms.)
Stock driveshafts should be fine.
Do you really want to stack blocks that tall on your rear axle though? You already have a three inch block in there.......
Old Apr 15, 2011 | 09:11 AM
Kwdog75's Avatar
Kwdog75
drop pitman arm is a good idea.
