Bosch Injectors
Old Apr 15, 2011 | 09:16 AM
Kwdog75's Avatar
Kwdog75
Default Bosch Injectors
I keep seeing them on Ebay as an "upgrade", has anyone tried these?
Or should i be the test guinea pig and try them?
Old Apr 15, 2011 | 09:17 AM
Link?
Old Apr 15, 2011 | 09:25 AM
Kwdog75's Avatar
Kwdog75
http://cgi.ebay.ca/97-98-99-Dodge-Ra...t_15000wt_1141
Hope the link works.
Old Apr 15, 2011 | 09:31 AM
Not much information on them...... just a claim that they are an 'upgrade'...... I think a better plan would be to call Five-O motorsports, and have a chat with them.
Old Apr 15, 2011 | 09:51 AM
Kwdog75's Avatar
Kwdog75
do they have a website?
Old Apr 15, 2011 | 10:19 AM
dipsherry's Avatar
dipsherry
yeah for that price i would b calling five o...i think there was a guy on here selling some red tops for 150 i willl look for the link...i only paid around a 100 for mine off ebay...but they were just 21lb 4 hole injectors as my truck is only bolt ons and no tune
Old Apr 15, 2011 | 10:20 AM
drewactual's Avatar
drewactual
be careful with injectors.. a matter of fact, if you MUST replace them, and your not doing it because your boosting or scraped/stroked up the displacement, just buy factory replacement.
I run the FMS GenIII 22#'s, and I run rich.. I managed to SCT back the duty cycle enough to stay safe, but that was only because I had the luxury of having the SCT and HemiFever around to help me out.. He pulled 5%, and I'm still rich.
FMS rate their injectors at 39psi- NOT the somewhat industry standard of 43.5psi.. That makes the injector deliver more than 22# by itself- it pushes it up to (let's say) 24#.. but our trucks don't run at 43.5psi at the rail.. they run at 49psi.. which means that 22# injector rated at 39psi is likely delivering into the 25~26# range at 49psi.. Or, better said: PIG rich..
Even Bruce at five-o will sell you a direct replacement injector (21# FMSgenIII) with a straight face- and I'm certainly not saying he doesn't know what he is talking about because that is his business and he no doubt DOES, but he isn't familiar with all vehicles fuel pressures and with injector timing either for that matter.. All of that will be up to you to know and reconcile against the information he can provide you.. And it is FAR more twisted a subject than you're likely considering.. case in point:
an injector from one brand may be 22# rated at 39psi, and so may a competitors brand deliver the rated 22# @ 39psi.. But if you bump the pressure on both to 49psi, one may deliver 24# and the other may deliver 27#.. you just don't know until you bench them.. add to that: the spray characteristics may be VERY suitable at 39psi, and far superior than stock injectors.. but, again, you bump the pressure and that nice little spray turns into a direct stream.. and you're in worse condition that you were to begin with.
Injectors that came stock are more than fine for most applications.. The headache those injectors I bought have caused are really not worth it.. I will be honest and tell you I was thinking they would be some sort of silver bullet- but they aren't.. even now that I have them trimmed right and timed differently- the increase is only marginal at best..
CM is the man to discuss this with.. Captain knows his business too.. If you can PM them and ask them for info I'm sure they will help you.
I just thought I'd toss this out there to help you out and possibly save you some money and headache..
Old Apr 15, 2011 | 10:35 AM
dipsherry's Avatar
dipsherry
https://dodgeforum.com/forum/parts-s...injectors.html
drew speaks the truth injectors are a complex thing...i got mine but changed plenum, timing chain, water pump oil pump, put hs 1.7 roller rockers on and did a keggar mod so to be honest i cant say how much the injectors helped...i am gonna buy a a/f gauge next paycheck to see how close my truck is to stoichiometric 14.7 - 1 air to fuel
Old Apr 15, 2011 | 04:01 PM
Kwdog75's Avatar
Kwdog75
The only reason i asked is because i bought a modded manifold (keggar), i figured why not replace the injectors while i was swapping the manifold.
Old Apr 15, 2011 | 05:04 PM
If you want to replace them.... just go for a stock set, that has been cleaned, and flow balanced.
