What mods do I need in order to tow in OD?
Old Apr 16, 2011 | 12:25 PM
vikingdiesel's Avatar
vikingdiesel
Default What mods do I need in order to tow in OD?
Is a trans Cooler all I need to tow between 2-6k lbs in OD? I Hate the 3k rpm revs in 3rd and I also hate the 9.5mpg,
Old Apr 16, 2011 | 12:39 PM
Gerehead8's Avatar
Gerehead8
I think the issue is a lack of lubrication of the OD unit when subjected to high loads. A cooler will help keep temps down but there needs to be more flow through the OD unit itself. Something like a sonnax sure cure may help.
Old Apr 16, 2011 | 01:07 PM
J415's Avatar
J415
Regardless if you tow or not, REMOVE YOUR CHECK VALVE!!!
Old Apr 16, 2011 | 01:08 PM
CPTAFW163's Avatar
CPTAFW163
a tranny cooler AND 5.88 gears.
towing that much weight in OD is asking for your tranny to go.
1900 for a new tranny, or a few more dollars in gas. Also, it is not advised that you tow going more than 65 MPH anyway. So unless you are going 80MPH, you should not be over 3K.
Old Apr 16, 2011 | 01:34 PM
aim4squirrels's Avatar
aim4squirrels
It is typically not advisable to tow in any gear ratio greater than 1:1. The ability to push the engine past the transmission can handle will always exist
Old Apr 16, 2011 | 01:38 PM
Mad_Scientist's Avatar
Mad_Scientist
Don't.
The od unit in these trannies is notorious for overheating anyway... why would you want to tow with it?
Old Apr 16, 2011 | 01:43 PM
vikingdiesel
ok, well I guess 3rd gear it is
Old Apr 17, 2011 | 02:41 AM
dhvaughan's Avatar
dhvaughan
there is a fix for the oiling/cooling problem, which would probably let you tow light loads in OD. it involves some extra holes or different parts or something...., plus a trans cooler. heavy loads should not use OD.
Old Apr 17, 2011 | 04:44 AM
intense00's Avatar
intense00
I thought that OD was ok to use, as long as the trans was not "hunting" between 3rd and OD. I have towed my 2K-ish LB pop-up with about 1000 lbs in the bed a few times and did use OD.
Hearing that I shouldn't tow at all with OD is bad news for me.
Old Apr 17, 2011 | 09:43 AM
dodgeramit_10's Avatar
dodgeramit_10
2K really? ur maxed out after a small trailer and lawn mower and I have no problem with OD.
