Rear end not aligned with wheel well
Old Apr 16, 2011 | 08:39 PM
AceWyatt's Avatar
AceWyatt
Default Rear end not aligned with wheel well
im curious how critical the alignment is with the rear wheels being centered in the wheel well. if you look at my truck in the "garage" youll see the rear wheels are closer towards the front of the truck and not centered properly. did buddy who put the lift in do this or is it natural? is it an easy fix? i can upload a closer shot of the wheel and wheel well if needed
Old Apr 16, 2011 | 10:25 PM
96magnumram's Avatar
96magnumram
What did he do flip the leaf spring brackets on the frame to get a couple more inches of lift in the rear??
Old Apr 17, 2011 | 01:42 PM
AceWyatt's Avatar
AceWyatt
not a clue man, all i know is when i look at a side view of the truck the wheel is way too far forward in the wheel well, its not centered at all. its about an inch and a half from touchin the well in the front and about 4 or 5 inchs from the rear lol
Old Apr 17, 2011 | 02:22 PM
ryan0714's Avatar
ryan0714
im suprized he hasnt had the drivetrain lock up. seems like it would throw off the alignment of the shaft and pinion angle or something.
Old Apr 17, 2011 | 03:15 PM
olyelr's Avatar
olyelr
If I had to guess, he probably put a shackle flip on it for lift in the rear, but didn't install a zero rate block. When you flip the shackle in the back (and don't lower the front spring mount the same distance) it will push the axle forward a few inches. A zero rate block allows the axle to be mounted in a different location on the springs, effectively centering the axle again.
Old Apr 18, 2011 | 07:00 PM
AceWyatt's Avatar
AceWyatt
http://s1212.photobucket.com/albums/cc460/acewyatt/ is the link to my photobucket of the result of the diff being turned up too high of an angle. this happened yesterday. the U shaped clips that hold the u-joint to the yoke tore apart and thats the result BLAH
Old Apr 18, 2011 | 08:14 PM
Looks for all the world like the u-bolts that hold the axle to the leaf springs simply weren't tight, and allowed the axle to shift under power.
Those don't look like stock blocks in the back either. No bump stop on 'em?
I didn't see a good pic of the rear spring mounts.
Old Apr 18, 2011 | 08:56 PM
97tn4x4's Avatar
97tn4x4
Those ubolts look loose in those pics.
Old Apr 18, 2011 | 09:20 PM
AceWyatt's Avatar
AceWyatt
i do believe the rear spring mounts are stock and they are un-damaged same with shocks, springs and mounts. the U-bolts could have been loose which would explain the topic of why the diff was turned up to high and off center of the wheel well, and the result is whats in the pics. now i just gotta find jackstands big enough to fit my truck and let the show begin lol.
Old Apr 18, 2011 | 10:25 PM
tweeker909's Avatar
tweeker909
