Removing Trim Package... thoughts?
Old Apr 20, 2011 | 09:41 AM
Originally Posted by Demoes4x
I took mine off before the new paint job. They looked tore up after 13 years. especially the chome film on the trim. It wasn't so hard removing them by just peeling them back and removing the adhesive then depending on your paint job you might be able to buff and blend the shade of color.
Here is a before and after.
BEFORE
AFTER
That is a beautiful truck. Very Nice.
Old Apr 20, 2011 | 10:31 AM
i mow grass's Avatar
i mow grass
Sharp looking truck after you removed the trim.
Demoes where did you get the bug guards for the hood/headlights? My truck was missing one when I bought it and I was looking to replace it.
Old Apr 20, 2011 | 11:15 AM
OLE BLUE97's Avatar
OLE BLUE97
seems like everyone wants to remove their trim. if anyone wants to sell/donate their V8 Magnum emblem, let me know. i want it!!
Old Apr 20, 2011 | 03:45 PM
Demoes4x's Avatar
Demoes4x
Thanks bud. Its a biiaatch keeping it clean though.
Thanks. Fleabay has them.
Mine tore up during removal. sorry .
Old Apr 20, 2011 | 06:52 PM
C.W.S.'s Avatar
C.W.S.
I have the bug gaurds over my headlights too, bought it as a kit with the grill one, headlight ones, headlight covers, and the window rain deflectors (i think) the rain deflectors may not have been in the kit.
Old Apr 23, 2011 | 07:44 AM
dadslittleredtruck's Avatar
dadslittleredtruck
Just spent two days taking the old trim off the 97 Flame Red Ram. The clearcoat wants to come off. I used a hair dryer on the high heat setting to heat up the tape underneath. Using a slim utility knife, I cut the adhesive from between the truck and the trim. I figured I'd rather see what I was doing, leaving more adhesive on the truck. Go slowly and the trim comes off fairly well.
Getting the trim off was easy compared to the adhesive left on the truck. I finally got it figured out, though. Goo Gone (WD-40 works too) and the cheapest plastic spoon you can find. Try the spoon that wants to break picking up Jello because it is softer and more flexible.
Soak the adhesive with Goo Gone and gently scrape with the spoon, bottom of the spoon towards you. The spoon flexes around the curves and lifts the adhesive. Once you find the right pressure, there are no scratches. Wipe clean and repeat if needed.
As I said, two days, but about two hours after figuring out the above method. I found lots of rust pits because of the open ends of the original trim, so gotta work on that now.
But it means more time in the garage, or as my wife calls it, the Office. Life is good.
Old Apr 25, 2011 | 09:38 PM
outlaw93z's Avatar
outlaw93z
OLE BLUE97, if you have some R/T emblems by chance, I'd gladly swap you for my V8 mag emblems! lol
