How to install an APC Air/Fuel Ration Gauge
a narrow band is completely inaccurate at anything above 14.7. this is due to the temperature variable when an engine is running rich. a voltage signal in the rich range is entirely dependent upon temperature as one voltage can indicate entirely different ratios. temperature is unmeasured with a narrowband sensor.
wideband sensors contain a current pump that determines actual o2 concentration and the level of o2 required to re-establish stoichiometric pressure AFR.
why would you need a gauge to tell you that you ARE running at the correct A/F ratio?
I needed a wideband, but only because i am running Bosch 24# injectors.
