Cant connect to OBD port
Old Apr 20, 2011 | 02:03 PM
If the engine starts and runs, and all your gauges work, the PCM is doing pretty much what it is supposed to, and points to a problem with the port itself, or, the wiring thereto.
What year is your truck?
Old Apr 20, 2011 | 08:48 PM
cblegy's Avatar
cblegy
97 ram 1500 cc 4x4 5.9 v8
Old Apr 20, 2011 | 11:09 PM
Novarider's Avatar
Novarider
Had the motor every been replaced? Someone could have done a hack job on the wiring
Old Apr 20, 2011 | 11:29 PM
cblegy's Avatar
cblegy
no all is orignal worked fine till about 6 mo ago
Old Apr 21, 2011 | 09:52 AM
Grab the 96 service manual from this thread. Start checking the wiring for your com port.
Old Apr 21, 2011 | 10:02 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Nope. Only one. Ford has their connectors under the hood. (at least, they used to....)
Reset the PCM by disconnecting the battery for a few minutes. Try your scanner again.
I believe US Federal Law states that starting with OBD II, the port has to be under the dash on the driver's side of the vehicle. A friend I grew up with, who is ASE Certified, stated that to me at one time and followed up that he HATES working on Volkswagens as VW buries the port deep under the dash.
Old Apr 21, 2011 | 10:04 AM
Wouldn't surprise me. It HAS been a while since last I worked on a ford.....
Old Apr 21, 2011 | 11:27 AM
babyhuey6810's Avatar
babyhuey6810
GM usually fuses the obd 2 port.The tipoff is when the cig lighter doesnt work and you cant get ecm data.Dont know about dodge,but its worth a look
Old Apr 21, 2011 | 02:41 PM
tweeker909's Avatar
tweeker909
The data link is set up with ISO 9141 protocol to receive/transmit data to/from the pcm. Pin 4-5 are grounds respectively and are obd2 required. Pin 4-5 can help troubleshoot many problems use a DVOM. Pin 7-15 is the k-L or high/low lines to receive/transmit data. ISO 9141 needs a wake up call back to the pcm on the low side inorder to receive/trans data and some scanners have a hard time with this.
Old Apr 22, 2011 | 06:58 PM
cblegy's Avatar
cblegy
i have used 5 diffrent scan tools
disco the battery for 24 hr no change
