Cant connect to OBD port
Old Apr 19, 2011 | 10:53 PM
cblegy's Avatar
cblegy
Default Cant connect to OBD port
i fixed my fuel code went to rest it scann tools cant connect
have power on pin 16
all connection are good
Old Apr 19, 2011 | 11:21 PM
J415's Avatar
J415
Check your scanner to make sure its not busted.
Old Apr 19, 2011 | 11:55 PM
cblegy's Avatar
cblegy
i have works on other truck fine
Old Apr 19, 2011 | 11:57 PM
JackJ's Avatar
JackJ
Others here have had this issue, some were able to remedy it by pushing in the back of the port while trying to connect. Sometimes the pins become loose and when you try and hook up they back out.
Old Apr 20, 2011 | 01:20 AM
cblegy's Avatar
cblegy
just went and tryed pushung the back of the plug still no connection
Old Apr 20, 2011 | 07:04 AM
Novarider's Avatar
Novarider
Isn't there another port under the hood somewhere? I remember someone telling me there are always two
Old Apr 20, 2011 | 10:07 AM
Nope. Only one. Ford has their connectors under the hood. (at least, they used to....)
Reset the PCM by disconnecting the battery for a few minutes. Try your scanner again.
Old Apr 20, 2011 | 12:51 PM
Smashed-And-RAM's Avatar
Smashed-And-RAM
EDIT: I need to practice reading comprehension before I post something. Sorry.
Old Apr 20, 2011 | 01:45 PM
cblegy's Avatar
cblegy
i have tryed to disco battery 12 hr no change
also dico the plug on the ecm no change
Old Apr 20, 2011 | 01:59 PM
cblegy's Avatar
cblegy
where and how is the ecm grounded
