need advice water pump went now knocking
Old Apr 22, 2011 | 08:17 AM
ryanmc's Avatar
ryanmc
Default need advice water pump went now knocking
i let a friend use my truck and water pump went on him i think he drove a couple miles after the belt popped off.
anyway i put a new pump and thermostat and it seemed good no smoke, no oil in rad and no collant in oil but when i accelerate it knocks. when it idle it doesnt knock. this is a 1500 3.9 im not sure if i should just drive it and wait for it to totally go, replace the motor or maybe i could replace a bearing or somthing? i guess its tough for anyone to know without hearing it what the issue is.im not really a motor guy but it sounds like a bearing.
any advice appreciated. im guessing if i have the motor replaced theyd have to take down the transmission its an auto maybe if they did take it down to replace engine i should have preventative work done to trany?
this truck has 205k its an 01 but ran great befor this.
Old Apr 22, 2011 | 08:21 AM
dnfd737's Avatar
dnfd737
plenum gasket?
Old Apr 22, 2011 | 08:24 AM
ryanmc's Avatar
ryanmc
i didnt replace it. that would make it knock when accelerating?
Old Apr 22, 2011 | 10:13 AM
Spark knock. Sounds like marbles in a tin can. Can you post a vid, with audio?
