All trucks wired same from Factory?
Old Apr 22, 2011 | 09:11 PM
DRP74's Avatar
DRP74
Default All trucks wired same from Factory?
OK so getting ready to do all the body work on my truck. The replacement doors I got are power but not heated mirrors. Mine are heated mirrors. If I leave the wiring in the donor doors but put my mirrors on will they plug in and work? Or do I need to change over all the wiring from my doors as well.
Also did Gen 2 trucks have a option for power slide rear window? Or just manual?
Old Apr 23, 2011 | 09:24 AM
DRP74's Avatar
DRP74
No one has an answer?
Old Apr 23, 2011 | 10:02 AM
Wiring for the heated mirrors on the door side is part of the mirror, so, changing the mirrors over to the new doors will work perfectly.
Old Apr 23, 2011 | 12:31 PM
Jimythefan's Avatar
Jimythefan
Heyyou is right. The doors are either wired for power mirrors or not. The heat wiring is included in the harness, so if the door has wiring for power mirrors then you get heat.
Old Apr 23, 2011 | 07:30 PM
DRP74's Avatar
DRP74
Thanks a lot. That's what i'm gonna do then. Now I want to find out if a Power sliding rear window was available in Gen 2 Rams.
