Hughes Power Package
Old Apr 25, 2011 | 12:49 PM
Hessian01's Avatar
Hessian01
Default Hughes Power Package
Hey guys,
I've been looking at the top end power package from Hughes engines, and was curious if any of you have installed it. I have a '96 5.2 Ram, and I'm wondering what kind of numbers I could expect after.
Here is a link to the aforementioned Top End Power Package: http://www.hughesengines.com/Index/p...=&partid=26112
Thanks!
Old Apr 26, 2011 | 12:17 AM
CPTAFW163's Avatar
CPTAFW163
probably close to this:
http://www.bionicdodge.com/bionic/in...p?topic=9197.0
Old Apr 26, 2011 | 02:26 AM
4085spd's Avatar
4085spd
With a 5.2 you may end up with pv clearance with that cams lift(flat top slugs). You may get away with a thickers head gasket but that kills compression and with aluminum heads you should bump up the ratio as aluminum runs cooler. HP wont see much more then 250 rwhp on a 5.2 they just dont respond to mods like a 5.9. 250rwhp is bolt-on power for a 5.9.... Put that combo on a 5.9 your looking at 300+rwhp. I would swap the eddy heads for the RHS INDY iron heads and with the money saved find a 5.9 short block.
Old Apr 26, 2011 | 07:06 AM
Hessian01's Avatar
Hessian01
Eh, I would but I'm trying to get a nice balance of mpg/hp. If I swap the motor, I might as well throw a 12 valve under the hood. Mpgs have been pretty steady at ~12.5, looking to get around 15-17.
Old Apr 26, 2011 | 07:48 AM
97tn4x4's Avatar
97tn4x4
A set of 2.02 iron ram heads would be alot mire cost effective IMO. Then just pick you a decent cam. You'd be surprised at the amount of lift they'll take. There's alot more to consider than the lift. It's very easy to "over cam" a 318.
Old Apr 26, 2011 | 09:05 AM
Putting on go-fast parts is NOT going to increase your fuel economy.......
Old Apr 26, 2011 | 09:12 AM
Hessian01's Avatar
Hessian01
Something like this? http://www.hughesengines.com/Index/p...6&partid=22248
More torque and efficiency is more MPGs if you can keep your foot out of it, no?
Old Apr 26, 2011 | 06:05 PM
97tn4x4's Avatar
97tn4x4
Yes but it's a very fine line between enough and too much.
Old Apr 26, 2011 | 06:30 PM
crazzywolfie's Avatar
crazzywolfie
at least that kit would get rid of the plenum gasket problem and would probably increase the fuel economy a tiny bit. i would never drop that type of money on an engine kit. you would probably be better off to get a tuner, cam and repair the plenum. the right cam could help your engine breath better and the rest could stay stock.
