high volume oil pump or not
Old Apr 28, 2011 | 06:06 AM
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by dipsherry
but it kinda makes sense more volume means it pushes more oil so it should be more pressure
If the engine is nice and tight, a high volume pump won't make any difference at all in oil pressure. But when things get sloppy it might happen that the standard volume pump just can't push enough oil to maintain proper pressure, and that's when the high volume pump will save the day and bring the pressure back up again -- because it can move enough oil to fill the gaps.
Old Apr 28, 2011 | 10:52 AM
dipsherry's Avatar
dipsherry
j415 thats a great video...pretty much summed it up. I got the h/v pump again just cause if i am gonna change it i wanna go with the best parts...
Old Apr 28, 2011 | 10:57 AM
dipsherry's Avatar
dipsherry
with 240xxx miles on original motor i wouldn't think she is to tight...she's prolly like a over worked **** star near retirement
Old Apr 28, 2011 | 02:03 PM
matty675's Avatar
matty675
my blueprinted pump came with a high pressure shim kit. with the kit installed it says 10-15 psi can be gained. still not sure if im going to install it or not.
Old Apr 28, 2011 | 07:42 PM
Yours doesn't need it. After all, everything is brand new.
Old Apr 28, 2011 | 09:33 PM
aim4squirrels's Avatar
aim4squirrels
High pressure, no. high volume, yes. might even think about a deeper pan with more capacity on that 408.
Old Apr 29, 2011 | 02:57 PM
matty675's Avatar
matty675
HAHAHA i keep getting SO many different oppinions! i was originally going to go with the HV but someone turned me against it!
Old Apr 29, 2011 | 03:08 PM
lazyboy's Avatar
lazyboy
HV does good things for internal cooling but watch your oil level closely. if you starve it the days over. deeper oil pan is not a bad combo with it.
I run HV in all my rebuilds.
Doug
Old Apr 30, 2011 | 11:49 AM
dipsherry's Avatar
dipsherry
ok got the pump in and my screen was clogged pretty darn bad...and oil pan was pretty nasty got it all cleaned up and now my oil pressure is about 70lbs at idle and hard on the skinny pedal she will top out the stock gauge...is that to much?
Old Apr 30, 2011 | 11:55 AM
Nope.
