plenum and timing chain question
i have a 97 dodge ram 1500 4x4 with 212,000 on it.. it has just recently started puffing blue smoke when i start it in the mornings then it goes right away after running for a few seconds..im to assume that this has soomething to do with the lower plenum gasket being blown out..im getting ready to do this fix (the hughes plate)..I want to get a new timing chain and do this while i have it apart..what would everyone recommend for a brand on timing chain..any double roller chain would work? is one brand better than the other?..any thoughts.. thanks guys
i just did this a few weeks back i got the comp cams double roller... i would do waterpump while down there cause it has to come off to get to timing chain...my truck runs smother starts easier now with the new chain my rig had 227xxx miles when i change my chain...she was sloppy
A bit of blue at startup may be valve seals as well. Given the mileage on your truck though, its a pretty good bet the plenum needs.... some attention....
I got this timing set. No problems with it. I noticed a BIG difference in the way the engine ran with JUST this fix.
Might also wanna replace the water pump, since you have to take it off to get to the timing set.
this is the timing set i got it works good for me and cant beat the price
http://www.summitracing.com/parts/CCA-2103/
Just did my t-chain over the 3 day Easter weekend. I got the comp cams double roller w/the advance and retard keyway notches. after reviewing the instructions I ended up using the factory setting. the instructions recommend this. I also got the t-chain tensioner as well and the fel-pro gasket kit (which lacked the O-ring for the heater bypass tube that started leaking, got a brand new heater bypass tube w/o-ring the next day from the "HELP?" section for $12) got everything from autozone for about $110. probably didn't need the tensioner with the double roller and a higher mileage engine but glad its in there now. give yourself two days of working easy and cleaning everything real well. I however noticed no difference in performance and my original t-chain was scary loose. haven't driven enough to comment on fuel mileage. by my thinking a loose t-chain actually retards timing ( the preferred for more power from these engines according to people that have done so with the selectable keyways on this forum) so I wasn't to surprised. also if you want autozone to be able to find the tensioner, look for same year 3.9 v6 for the right part #. it doesn't seem listed as an option for the 5.9 v8 in their system. also a tip, if your not changing the water pump you don't need to remove the fan from it. mine was giving me fits and I have the right size wrench and holding tool. seems it could be reverse threads or maybe not. so I just removed the wp, fan and shroud at the same time. saved some time and aggravation.
i got this set its the same as the one dipsherry posted but you get free shipping from amazon so its 45 after shipping.
http://www.amazon.com/Competition-Ca...T04WFSPCSAXMN1
I got the timing set from Hughes when I ordered the plenum kit. It lists at $92 but seems to be a quality set. 3 keyways (+2, 0, -2) but I just went dot to dot. Made by Progear, but I cant comment whether this one is better than any other. I know price doesnt mean quality but I wanted the best thing I could afford.
+1 on the water pump removal. I moved the fan shroud back over the fan, removed radiator, then shroud, then water pump. no hassles.
Trending Topics
thanks guys on the ideas.. i have done the water pump last year that seems to be good no leaks..also i have a 195 t stat in it now i think im gonna be installing the 180 when it goes back together..any preferences on brand of t stat any one work better than the other i have a carquest in it now which is made by stant i do believe..
have a 5 gallon bucket to catch fuild,, then removing sum of the timing chain bolts keep the bucket because a few of them when removed coolet will come out
also try not to damage the oil pan gasket, i put a little rtv on mine reinstalling
