94 Dodge Ram 5speed
Old Apr 28, 2011 | 09:11 PM
SpencerS's Avatar
SpencerS
Default 94 Dodge Ram 5speed
Hey guys,
I had a dodge dakota for a long time, then took a break from the dodge family for awhile. Now im back in with a 94 dodge ram 1500. Its a 4x4, 5.2, 5 speed. I picked it up for 2,000 and am looking to fix a few things on it and had a few questions.
Problems:
-around the passenger side wheel i hear a clicking sound when braking, it is pretty aparent and not feint. Could this be the u-joints on the axle?
-It has a janky muffler setup on it im probably going to cut it off and put new piping with a quieter muffler(prolly a cheap glasspack or fake flowmaster). What size piping will i need from the manifold back?
Questions:
What kind of straight axle is on this truck? Dana 44? High Pinion?
Stock gear ratio?
Transfer case ratio?
Now i made a Cold Air Intake for my dakota with some ABS piping and clamped a Filter on the end, can i do the same with the ram?
Also as far as Programmers go what are my options?
Ive been on this site a long time and am definitely looking forward to posting up again. Thanks guys!
Old Apr 28, 2011 | 11:00 PM
dodgeman2289's Avatar
dodgeman2289
as for the intake yes u can make ur own.. but specte makes one for 120 or so.. and mopar performance makes a cirlce one for 77 like an old muscle car would have.. only thing u can get for the pcm is a a mopar pcm. programmers wont work cause u dont have obII port because its 94. i believe ur rear end gear is either the 3.55 or 3.92 id say 3.55 not sure with the trans case. and not sure about the noise u hear but somone else will comment more about it..
Old Apr 28, 2011 | 11:29 PM
Gerehead8's Avatar
Gerehead8
Front axle is Dana 44, low pinion (you can look at it and tell).
Most likely 3.55 axle ratio, look at the underside of the hood for a tag.
T-case is NP231 which has a 2.72:1 low range.
Tuners - Mopar PCM, B&G flash, custom (Megasquirt ect)
