cyl 1 and 2 misfire
Old Apr 30, 2011 | 12:42 AM
rond97sport's Avatar
rond97sport
Default cyl 1 and 2 misfire
wow you know im just baffled.ive replaced nearly everything except cam and lifters.i cannot get rid of the 1 and 2 misfire .all other cylinders perfect 1 misses a little maybe 20 counts in a minute 2 misses a lot off and on sometimes it wont skip at all .and you almost cant even notice the dang misfire its very small.otherwise the truck runs awesome.truck info ;97 ram 1500 2wd 5.2l ,new injectors,plugs,wires,cap and rotor,t stat,ecm temp sensor,#1 o2 sensor ,plenum is tight and dry.new pcv ,new coil coming this weekend,im hearing just the lightest little lifter tap on the right side front so maybe a worn lifter issue.i dont know.gonna do a leak down test i guess.anybody got any ideas?
Old Apr 30, 2011 | 12:54 AM
Mad_Scientist's Avatar
Mad_Scientist
Compression test time. The lifter tick is probably unrelated, and even if it does have something to do with it, it would only explain one cylinder.
It could be the coil... seen as how 1&2 cylinder pulses have to travel the farthest (longest wires) they would be the first to have a problem if the coil isn't firing as it should. It should be noted, however, that this is just a theory based on my understanding of the physics of electricity.
Old Apr 30, 2011 | 01:00 AM
mike.97.2500's Avatar
mike.97.2500
im having the same issues missfire cyl #'s 3, 4, 6 doin some testing tomorrow ill let you know if i find anything funny and ill be keepin an eye on your problem incase you find somethin that fixes yours maybe a similar problem good luck
Old Apr 30, 2011 | 01:16 AM
rond97sport
new coil will be here monday.ill connect the scanner and see if that fixes it or not.i think im gonna pull the cap and make sure there is no contamination present as well.
Old Apr 30, 2011 | 01:27 AM
mike.97.2500
i just replaced my cap and rotor a month ago but will be checking it again tomorrow for unusual wear i was told in my thread to crank the motor and watch for wobble on the rotor with the cap off and then take the rotor off and do the same and watch the shaft. also to look for excessive play in the distributer too hopefully that helps you ill be doing it all tomorrow ill let you know.
Old May 14, 2011 | 12:08 AM
rond97sport
well still skipping .replaced coil.leak down test good.only does it hot at idle.guessing im gonna have to do the plenum gasket.no other possible cause.
Old Aug 2, 2011 | 02:53 PM
97ramtruck's Avatar
97ramtruck
Default misfire counts
How are you reading the misfire counts for your cylinders? I just bought a scan tool which displays mode $06 data but I can't seem to find out how to see the individual cylinders and misfire counts. Did you fix your problem?
Old Aug 4, 2011 | 12:59 AM
rond97sport
i have an otc genesis.no i didnt fix it im assuming its a cracked head issue at this point there is nothing else to do to it.the truck is for sale at this point i dont need a money pit.
