Coolant Temp Gauge
Old May 2, 2011 | 07:56 PM
Demoes4x's Avatar
Demoes4x
Default Coolant Temp Gauge
I was thinking of connecting the pilar mount coolant temp gauge to the existing (oem) coolant sensor by tapping into the wires. Has any one done this.
Old May 2, 2011 | 08:36 PM
Gerehead8's Avatar
Gerehead8
Out of curiosity what do expect to gain?
I wonder if the aftermarket gauge would even read properly. It may be expecting different resistances from different temperatures.
Old May 3, 2011 | 07:31 AM
Novarider's Avatar
Novarider
Why would you want two of the same gauge? I would unhook the stock sending unit and replace it worth the aftermarket one that comes with the gauge
Old May 3, 2011 | 10:34 AM
Demoes4x's Avatar
Demoes4x
OEM is PRE radiator the one I'll be installing will be POST radiator.
I wanted to splice into the EOM wires with a switch connected to the after market gauge to read both PRE and POST temps.
Why to the OEM one you might ask. I think the after market one is more acccurate.
I'll be able to monitor the radiator this way.
