need cam advice
Old May 5, 2011 | 08:37 AM
u-shoot-irak's Avatar
u-shoot-irak
Thanks for info. On my way out to pull 318 out and paint more parts. Hopefully have truck ready so I can pull bass boat before season opens. I will surely have more questions as I go. Thanks again.
Old May 5, 2011 | 08:39 AM
u-shoot-irak
I have 98 318 truck with cpu and harness already there. I also have cpu and harness that came with the 95 360
Old May 5, 2011 | 10:49 AM
Port is different for the 98, but, the 95 does have one.
There are also trans differences you will have to deal with. OBDII transmissions are all electronically controlled.
Old May 5, 2011 | 11:39 AM
dodgeram07's Avatar
dodgeram07
Your ok just use everything on the 98 wiring ect and the intake manitfold off the 98. Use the 95 motor with the 98 Intake
Computer get ahold of hemifever sct tuner he use the 318 computer and make it work with the 360
As the cam goes if I make it home tonight I will get u sum info
Old May 5, 2011 | 11:41 PM
dodgeram07's Avatar
dodgeram07
the 318 cam has more lift than a 360 cam
my computer is acting funny or i would have sum links,,,oh well im going to bed
Old May 6, 2011 | 12:29 AM
dodgeman2289's Avatar
dodgeman2289
ya id love to get my hands on a 318 cam and switch my 360 one for the 318.. id be happy with that.. all other cams are lowest 480 lift with 1.5 stock ratio! i already have the 1.7s so the 318 cam would work great for me!! seeing as i dont really wana go huge in the cam department.
Old May 6, 2011 | 12:36 AM
97tn4x4's Avatar
97tn4x4
Almost all "pre grind" cams are for 1.5. But when you put them on our 1.6 or if you go to 1.7's that lift gets alot higher.
Old May 6, 2011 | 11:23 AM
u-shoot-irak
If you don't mind a used one I have the cam out of 98 318. A friend of mine has everything to measure wear I am going to have its specs soon it is still in my truck but should be out within a couple of days as long as i have time to get out there. I only have tranny bolts and exaust to remove before yanking out the engine. And one stupid motor mount bolt that will be manhandled today
Old May 6, 2011 | 11:35 AM
u-shoot-irak
Pulled oil pan plug and over filled oil pan with water and sludge all over my driveway. Gotta go power wash. I can't work under there without laying in it
Old May 6, 2011 | 11:40 AM
u-shoot-irak
If I put headers with true duals and elimanate cat is there a way to reposition sensor so computer won't be confused???
