Timing Chain Slack
Old May 6, 2011 | 12:53 PM
Ramcountryboy's Avatar
Ramcountryboy
Default Timing Chain Slack
Hey ya'll, I replaced my timing chain yesterday, the old one had tons of slack, but the new one has a little, is that normal? Last year I did the timing chain in my 89' ram, it was super tight, it was a double roller deal though, so I'm not sure if that makes a difference? Anyway, any advice would be appreciated, thanks!
Old May 6, 2011 | 04:33 PM
Ramcountryboy
I measured the slack on the new timing chain, with the one side tight, had about 3/8in of play, if that helps determine if thats normal or not.
Old May 6, 2011 | 06:41 PM
aim4squirrels's Avatar
aim4squirrels
I've replaced the chain twice on my truck, both new sets were tight as hell and hard to get the sprockets on. Sure you got the correct part number?
Old May 8, 2011 | 10:00 PM
Ramcountryboy
Yeah, I'm sure it was the right number. It's alot better than the old one, so I ended up putting it on... hopefully it lasts a while. Thanks for the reply
Old May 8, 2011 | 10:40 PM
matty675's Avatar
matty675
you should have used a double roller and replaced the thrust plate with a tensioner
