shifting late hits rev limiter
Old May 8, 2011 | 10:36 PM
dodgeman2289's Avatar
dodgeman2289
Default shifting late hits rev limiter
so the video below is a guy on youtube who's truck does exactly wut mine does... ive adjusted the tv cable both forward and back to try and fix this but with no luck and i dont move it much just a hair... seems to only happen when im already moving and punch it.. but if i go from a stop and punch it it will shift right most of the time.. also on some cases my 2nd to 3rd gear will go in neutral or something goes out of gear and revs up then i let off it and its good... first time it did it i adjusted the tv cable and stopped. i got the adjusting the tv cable from someone on here cause when i installed my throttle body and intake it started going out of gear in between 2-3 gear so he said give it a try and it worked. but the late shift been driving me crazy so i thought it still wasnt right . seems im not the only one who is having this problem.. clearly this video shows!
http://www.youtube.com/watch?v=hsxAL0XUDWk
Old May 8, 2011 | 10:42 PM
Gerehead8's Avatar
Gerehead8
I bet a bad governor pressure solenoid or sensor or whatever it is.
Old May 8, 2011 | 10:46 PM
97tn4x4's Avatar
97tn4x4
Yeah the design of it it allows fluid to fill it and doesn't work properly. Theres a gm style sensor to correct this problem.
Old May 8, 2011 | 10:53 PM
dodgeman2289
wheres it located???
Old May 9, 2011 | 12:03 AM
97tn4x4's Avatar
97tn4x4
It's inside the trans, I believe you have to drop the valve body to get to it.
Old May 9, 2011 | 12:28 AM
dodgeman2289
i just changed my tps sensor.. i had an extra off a thrrotle body that i bought off a guy who ported it.. was off a dakota but i dont think it matters it was a 5.9 will see if that was a problem i heard it could be if its worn out!
Old May 9, 2011 | 12:35 AM
97tn4x4's Avatar
97tn4x4
The tps shouldn't affect the shift points.
Old May 9, 2011 | 01:19 AM
dodgeman2289
on a different forum a few guys changed/adjusted theirs and it made a big difference for them i posted a forum on it
Old May 15, 2011 | 09:48 PM
dodgeman2289
hey do you by chance know the link is to that silanoid. thing to fix my problem.. u said theres a gm version to fx my problem.
Old May 15, 2011 | 09:55 PM
Here ya go.
