Weird miss
Old May 9, 2011 | 08:29 AM
dipsherry's Avatar
dipsherry
Default Weird miss
Ok if u get on my truck hard from a dead stop. It will miss terribley. And sounds like it is back firing. But if u lift up and ease into the throttle it is fine. could this b my coil. (i have the wonderful accel) I doubt its my injectors cause it just developed this problem.
Old May 9, 2011 | 09:16 AM
redheadhunter21's Avatar
redheadhunter21
I would start at checking the plugs and the wires, then cap and rotor.....also do you have any codes
Old May 9, 2011 | 09:17 AM
drewactual's Avatar
drewactual
because it's an accel, that would be my first place to look..
Old May 9, 2011 | 11:11 AM
97tn4x4's Avatar
97tn4x4
Maybe the tps not reading correctly?
Old May 9, 2011 | 11:12 AM
dipsherry's Avatar
dipsherry
Sorry for double post stupid phone froze
Old May 9, 2011 | 11:14 AM
aim4squirrels's Avatar
aim4squirrels
Its either air, fuel, or spark.
Verify fuel pressure at the rail at 49psi.
Check wires for loss of signal whilend checking ohms.
Visually inspect plugs, cap and rotor.
Swap coil for a known good one,
Then start looking at sensors.
dipsherry's Avatar
dipsherry
No codes cap rotor wires all look good. Guess stock coil is going back on tonight
