caster bolts?
Old May 11, 2011 | 09:34 PM
smcandrew08's Avatar
smcandrew08
Default caster bolts?
Hey guys so i stupidly didnt mark where the lines were at on the caster bolts when i dropped my lower control arms from the axle. Is that going to have any affect on the alignment of the truck?
Old May 11, 2011 | 09:59 PM
97tn4x4's Avatar
97tn4x4
Yep they need to go back where they came from.
Old May 11, 2011 | 10:25 PM
You will have to take it in and get it aligned. Grab the specs from Geno's Garage, and have it set to those.
Old May 13, 2011 | 03:53 AM
smcandrew08
alright that was what i was thinking thanks heyYou. So having those bolts not in the same spot as they were before wont mess with the caster of the axle or anything will it?
Old May 13, 2011 | 08:23 AM
Those bolts adjust the caster, so, if they are not in the right spot, you will be out of spec...... Take it in, and get an alignment. Use the specs mentioned above. You will be much happier for it.
