Cruise Control quit on me.
Old May 14, 2011 | 10:22 AM
dhvaughan's Avatar
dhvaughan
Originally Posted by SpencerS
Yea the vaccume on my ram is broke and brittle in alot of the line so i am going to replace that line. Is there any change if my ABS light is on only some of the time? How do i fix that?
cruise control operation needs a speed sensor signal from the computer (and trans) to work right. fix any vac lines first. if it still doesn't work, or you get ABS light, consider the speed sensor in the tail shaft of trans/tcase, its about $15-20.
Old May 14, 2011 | 10:26 AM
ShelbyGT550's Avatar
ShelbyGT550
My fathers 1995 ram did the same thing, worked one day and the next it would not engage, turned out to be the vacuum line under the battery fell apart
Old May 14, 2011 | 05:33 PM
AZJOE's Avatar
AZJOE
Same here, corrosion from battery damaged vacuum line.
Old May 14, 2011 | 07:06 PM
99ram15005.9's Avatar
99ram15005.9
Well i just found my problem the little hose going into the intake had came off, now it works just like normal thanks guys
