headers
Yep, you could get the magaflow direct fit high flow cat. That comes with the "Y-Pipe" tubing and everything.
well i needed a cat for emissions, i had to buy one as mine was plugged up pretty badly it lasted a week... the truck already ate it alive.
im planning on cutting it off altogether today and running pipe back coem thursday unless someone suggests something diffrent because i have a complete loss of power again the Pre cat o2 sensor is giving off a code again basically everything it did before i replaced the cat..... ran good for a few days though lol
I think the reason they cracked is because when I first installed them the y-pipe didn't fit quite right, I had to squeeze the crap out of it to make it slip onto the headers. So those headers were under tension for quite a while, not any more though.
Y'up. The same here. The y pipe didn't meet up. They were about 1-2 inches off center. That wasn't my biggest problem. There wasn't that much clearance to put the bolts in...especially the 2 rear bolts on the drivers side. I gave up and sold them for $80. Lesson learned.
I think the crack helped mine fit into place because when I put my new cat on the truck I had to pull the y-pipe and it fit perfectly when I put it back on. It sucks that I didn't see the crack when I did that though, I drove the truck for a good while after that before I found the crack. But it wasn't a big deal to weld the crack shut so I would recommend these to anyone that has access to a welder in case they do end up cracking.
check the vac lines from the charcoal canister to the purge valve/throttle body. you might be sucking in and passing charcoal through your engine. i saw a buddy's 1st gen do that and it completely stopped up his cat to where it wouldn't even run.
