"click click click" per rpm rate when gas pedal used
check rear drive shaft u-joints. truck level, in neutral, parking brake off, wheels blocked.... (don't get run over), and with all tension off the drive line - rotate the joint halves against each other. seal should be intact and no movement/play. you can use a screwdriver for a little extra leverage.
Trending Topics
a collapsed lifter only makes a tick- there are other ways to tell, but only if you are looking for a collapsed lifter..
an exhaust leak can be found real quick like with some seafoam through the brake booster line into the intake manifold..
u-joints can be confirmed by crawling up under there and shaking the shafts (yeah, I said that, leave it alone now) to see if there is ANY play there..
a timing chain that is excessively loose can slap, and sound like a tick.. that will also follow the tach's rhythm.
a rod or knuckle joint can tick.. let's hope it isn't a rod or knuckle joint..
a harmonic balancer can tic.. you'll see it wobbling up the rotation of the belt though..
