Noisy power steering line... High pressure
Old Nov 14, 2011 | 10:04 AM
  #21
Bustedknuckles's Avatar
Bustedknuckles
Default John... brakes/steering causing the noise
John,
you stated that the noise changes when you load the steering OR brakes... i'm assuming then that you have a cummins? usually on the deisel applications the steering and brakes are hydraulically assisted via the pump.
in my case it was just steering as i have the 5.7hemi.
i believe there is some history of the deisel applicaitons having a problem with a plastic "isolator" inside the HP line coming loose and causing the vibration/hissing sound. should be an easy fix and obviously covered under warranty.
Old Apr 21, 2012 | 10:44 AM
  #22
Sharon Rubeck Fortune's Avatar
Default power steering noise
i started by replacing a leaking power steering hose and after that got a noise so i changed the pump and still had the noise so i changed the steering box and still had the noise i am going to replace the hose one more time ma be a bad hose i hope
Old Sep 1, 2012 | 04:18 AM
  #23
konvertre's Avatar
konvertre
Thumbs up fluid
I used some lucas power steering fluid treatment which i believe slightly thickens the ps fluid, my noise reduced by about 90% and so far no increase
