ok 13 and 6 on cab connector have no ground does it need to be plugged into get ground or is that a frame ground.
can i cut them and make them a frame ground
well fixed ground abs light went out. going for test drive now speedo is still at 120 hope i didn't fry that trying to find the problem i will let ya no the out come in about 15 min
thanks a **** load HeyYou
and the rest of you all your help was great !!
Is that from the connector on the ABS controller? If so, those should go directly to ground. (no resistance between the terminals on the connector, and a ground location on the truck, whatever happens to be convenient.)
Both ground at G101, which is at the front of the truck, drivers side, by the radiator. Check and clean that ground.
