Plenum welding
Old May 22, 2011 | 06:55 PM
kejobe's Avatar
kejobe
Default Plenum welding
What, if any cons are there to welding the hughes plate to the intake? I've searched but haven't came up with anything useful. I have access to a tig and a good welder if i don't think i can do it myself being aluminum.
Old May 22, 2011 | 07:14 PM
97tn4x4's Avatar
97tn4x4
I always wondered about this and I look forward to seeing what everyone has to say about it. I do know you have to be careful welding cast aluminum.
Old May 22, 2011 | 07:27 PM
J415's Avatar
J415
The only con, if any, would be that you can no longer access the inside of the kegger.
Old May 22, 2011 | 07:52 PM
kejobe's Avatar
kejobe
I have no need to get inside, so i dont see why it wouldnt be better. As far as welding cast alum., the machinest where i work has been welding all types of material for his entire life. Hes 69 now so its been awhile.
Old May 22, 2011 | 08:36 PM
J415's Avatar
J415
What about the kegger mod? Have you done that yet? Do you even want to do it?
Old May 22, 2011 | 08:52 PM
kejobe's Avatar
kejobe
Not really interested in it. I may be mistaken, but from what seen it doesnt seem to be worth all the work to me.
Old May 22, 2011 | 09:23 PM
Adobedude's Avatar
Adobedude
Neither does welding on a Plate...
I'd be afraid it would warp the manifold, as in it will.
Old May 22, 2011 | 09:38 PM
kejobe's Avatar
kejobe
As long as you take your time and allow things to cool as you weld it will be fine. I do autobody as well. It works the same with sheet metal. If you get to hot, yes it will warp.
Old May 22, 2011 | 09:52 PM
Adobedude's Avatar
Adobedude
Sounds like your dead set on welding it on, you have shot down anything anyone has posted....Why did you even ask for any opinions?
Weld away...
Old May 22, 2011 | 10:05 PM
CPTAFW163's Avatar
CPTAFW163
the only reason you would weld it is if you are running 6-10 PSI of boost.
And if you do want to do it, forget the TIG, just use durafix. it will not warp:
http://www.youtube.com/watch?v=jijW310xvp4
