Dual Battery?
Old 05-23-2011 | 11:35 PM
offroadjosh's Avatar
offroadjosh
Default Dual Battery?
So now that i have the winch mounted, HAm/fire radio, CB(soon), more off road lights(soon) and a power inverter on my truck plus other goodies and i leave the ignition on often i want to install a dual battery setup. Any ideas how hard/easy? Cost? thanks
Old 05-23-2011 | 11:51 PM
BigRedRam95's Avatar
BigRedRam95
I have all the stuff to hook up mine just need to go out and do it. I am going to put mine on a switch so I can turn it on when I want and off when I want. I'm using welder cable for the battery cables.
Old 05-24-2011 | 12:07 AM
Grab a GOOD dual battery isolator, some cable fatter than you think you really need..... and the passenger side battery tray bits from der diesel truck..... (if you can find one...)
What size alt do you have?
Old 05-24-2011 | 12:10 AM
redheadhunter21's Avatar
redheadhunter21
Battery, tray and a decent alt if you dont have one already.....looking at $400 bucks or so with wire
Old 05-24-2011 | 12:42 AM
offroadjosh
Have the 192amp one i think? one that came with the tow package...(the biggest one aval with the 1500)
Old 05-24-2011 | 04:50 AM
99dodge318's Avatar
99dodge318
ive been thinking about this also just i dont know how to wire in a second battery.
Old 05-24-2011 | 09:17 AM
Novarider's Avatar
Novarider
Wouldn't you just wire them in parallel? Positive of one battery to negative of the other then hook the remaining two cables like its one battery. That should double the capacity of the batteries and leave the voltage at 12
Old 05-24-2011 | 09:40 AM
charlie1935's Avatar
charlie1935
Wiring them like that is series. Don't do that!! I don't think the 24 volts would do the electronics any good.
Parallel is positive to positive, negative to negative or to ground.
Old 05-24-2011 | 10:21 AM
redheadhunter21
Agreed with charlie wire together not opposite
Old 05-24-2011 | 10:48 AM
Novarider's Avatar
Novarider
It's been a while since I had to think about wiring batteries. I always seem to get them mixed up
Quick Reply: Dual Battery?
