Leaf springs, coil springs
Old May 25, 2011 | 04:33 PM
BigRedRam95's Avatar
BigRedRam95
Default Leaf springs, coil springs
OK I know this has been up a few times but I cant find the old threads.
I am going to get a set of rear leaf springs,blocks,and frame brackets from a 2001 reg cab 4x4 ctd truck tomorrow. I know the front coil springs give you about 3 inches of lift but will the rear leafs give me any lift? Also how many leafs do some of you guys have in your 2500 and 3500 trucks? Thanks
Old May 25, 2011 | 05:00 PM
97tn4x4's Avatar
97tn4x4
I have to ask why the 2500 springs?
Old May 25, 2011 | 05:06 PM
BigRedRam95
I was hoping it would lift the truck and the rear would be stiffer.
Old May 25, 2011 | 05:17 PM
The 3/4 ton trucks sit a couple inches higher than their half ton counterparts.. so yeah, you will get a bit of lift out of it, and it will most certainly be stiffer.... Might have a bit of a problem with the spring pads on the axle though, the 3/4 ton springs are wider.....
Old May 25, 2011 | 05:25 PM
97tn4x4's Avatar
97tn4x4
The 3/4 tons don't get there lift from the springs though. You might gain 3/4 inch, just because they won't sag as much. It will be easier and more effective to just put a add a leaf in.
Old May 25, 2011 | 05:33 PM
redneck_ram's Avatar
redneck_ram
im going to be doing the same thing in a couple weeks! tired of my truck dropping so much when i put weight in the bed, or when i hook up my camper. im also going to be getting a set of 3/4 ton axles. im not sure if im going to get a 60, 70, or 80 rear end, but i know ill be going with 4.10's!
Old May 25, 2011 | 05:47 PM
97tn4x4's Avatar
97tn4x4
My truck with 4k on it sags 'maybe' an inch. That's with aals.
Old May 25, 2011 | 05:59 PM
BigRedRam95
Well I am going to get the springs cheep we are going to trade. I might be getting the front and rear end from him if it has 4.10s in it. It just sucks because last year I got 4.10s put I'm my half ton axles.
Old May 25, 2011 | 06:01 PM
97tn4x4's Avatar
97tn4x4
Then why not just keep what you've got and spend 70 bucks? Since you're not gonna gain any towing capacity or anything.
Old May 25, 2011 | 06:10 PM
BigRedRam95
Because it is a 1/4 qt of mixed paint and will go bad if it sits too long and I am going to help him cut up the frame that was under my truck to get it out of his yard. My truck wont sag as much when I tow with it right. Also the blocks are taller right?
