Need Help Please!!
Old May 27, 2011 | 08:51 PM
sxe_death_eather's Avatar
sxe_death_eather
Default Need Help Please!!
So heres the thing i have a 2000 dodge ram with a 5.2 i ended up swapping the motor for a 5.9 and i have the computer for that motor but now my instrument cluster is not working all it says is "no bus" i am using the harness for the 5.2 and when i use the 5.2 computer on the 5.9 motor the cluster works its only with that computer or any other 5.9 computer ive used .. will i have to switch that??
Old May 27, 2011 | 08:59 PM
95RAM360's Avatar
95RAM360
were the motors/computers the same year?
Old May 27, 2011 | 09:01 PM
sxe_death_eather
yes same year its the computer that came with the motor
Old May 27, 2011 | 09:07 PM
95RAM360's Avatar
95RAM360
maybe you need a 5.9 harness....ive heard of some people with an '00 ram haveing similar problems...
sorry i couldnt help much, but im sure one of the other gurus will chime in
Old May 27, 2011 | 10:04 PM
What year was the motor/pcm combo that you got?
Old May 27, 2011 | 10:43 PM
sxe_death_eather
Its A 98
Old May 27, 2011 | 11:11 PM
Hhhhmmmm..... that should work.....
As opposed to buying yet another PCM though.... contact Hemifever Tuning, and see if he can't send you a tuner for your stock 5.2 computer, to program it for the 5.9. (should be under 300 bucks.)
Another alternative would be, find a 2000 truck, with the 5.9, and the same trans you got. Give that a shot.
Old May 28, 2011 | 06:22 AM
Randy_W's Avatar
Randy_W
I've done a bunch of swaps and I can tell you from much experience, if you run the 360 on the 318 PCM it will run fine and you'll never know the difference on stock motors. For absolute best performance get a pro tune done. In my '01 Silverado sb, rc 2wd I ran 4.8 PCM on an LS1 for over2 years and the truck ran perfectly fine and would blow the doors off a similar Hemi Ram. Now that generation of GM PCM has more self learning capability than our Dodge pcm's from the 2nd gen do, but it will still work fine.
Old May 28, 2011 | 07:46 AM
neilsrpcustoms's Avatar
neilsrpcustoms
The problem is probably with the mileage on the computer. If the mileage isn't the same across all components on the bus circuit,it may give you a no bus. It may be accepting it on the one computer and not the other
Old May 28, 2011 | 08:00 AM
bwdakrt's Avatar
bwdakrt
Use your 5.2 PCM and call it done. Otherwise, you'll have to have the dealer change the vin # in the 5.9 PCM.
And a little FYI, the mileage is stored in the insturment cluster and not the PCM.
