Code 0443 in odometer
Old May 30, 2011 | 04:39 PM
GmDude66's Avatar
GmDude66
Default Code 0443 in odometer
Hello, today I noticed my check engine light was on in my 2000 Ram 1500. I took it to autozone and their tester did not report any codes. I did the 3x key cycle and I got a code of P 0443 on the odometer.
The only thing I did to the truck was refill it with r134a t get the AC to be cold. The AC wasn't cold since I got the truck over a year ago. (it was so empty the compressor wouldn't even turn on)
Anyone have any ideas?
Old May 30, 2011 | 05:08 PM
P0443 Evap Purge Solenoid Circ
I think your solenoid is on the passenger side wheel well toward the front..... not sure if this would be an electrical problem, or, possibly a vacuum leak.
Old May 30, 2011 | 07:24 PM
dhvaughan's Avatar
dhvaughan
the purge solenoid is on the passenger side fender well, in the same area as the AC lines and charging port. its got about 4 or 5 vac lines attached. see if you bumped it in the wrong way, check the vac lines, check the electrical plug. maybe unplug and replug it.
Old May 31, 2011 | 10:53 AM
GmDude66's Avatar
GmDude66
Checked the lines for leaks and also unplugged and reinserted the electrical plug. Then I cleared the DTC with my sc3865.
Let's see if that solves the problem, will post back with results!
