8 lug Axle shafts
Subscribe
Jun 2, 2011 | 01:30 AM
The 94-95 Dodge Ram LD 2500 has a Chrysler 9.25 in the back with 8 lug axle shafts. Would they be the same length and width as the shafts in my 01 Dodge ram 1500 with a 9.25 in the back with 5 lug axles? Im throwing a Dana 60 in the Front and would like to have 8 lugs in the back too. Any help would be great!
Reply 0
Jun 2, 2011 | 04:27 AM
Yep they're the same length.
Reply 0
Jun 2, 2011 | 12:00 PM
Is there any spec page out there that shows the dimensions of the most common axles.? So if they are the same length i will just need new drums also and thats it?
Reply 0
Jun 2, 2011 | 12:28 PM
Quote: Is there any spec page out there that shows the dimensions of the most common axles.? So if they are the same length i will just need new drums also and thats it?
You will need the drums AND the backing plates as well.
Reply 0
Jun 2, 2011 | 01:43 PM
Okay , but the breaks with still work right? same size drums? has anyone else on here done this before?
Reply 0
Jun 2, 2011 | 01:46 PM
I would like to think the drums on even the LD 3/4 ton are going to be larger than the half ton....... so, with the correct drums, and backing plates, just put 'em back together with the LD 3/4 ton rear brakes, and you should be golden.
Reply 0
Jun 2, 2011 | 01:51 PM
Im starting to think that throwing a D60 or D70 in the back would be just that much easier because i dont know how available these parts are
Reply 0
Subscribe
