Clicking from front end.
Old Jun 25, 2011 | 05:27 PM
  #21
blackbeasst's Avatar
blackbeasst
Tires picking up rocks?
not on mine. im pretty sure mine is a metal on metal vibration
Old Jun 25, 2011 | 06:35 PM
  #22
Is it a rattle? Or a buzz? For a rattle, look at the heat shields around the engine mounts. If its a buzz, check the heatshield on the cat. Also look at the dust shields on the front.... provided they haven't rusted completely away...
Old Jun 25, 2011 | 06:53 PM
  #23
blackbeasst
nah mine for sure is a rattle. don't really hear it until i get about 25-30 going both ways.
Old Jun 26, 2011 | 04:46 AM
  #24
S S0DEN's Avatar
S S0DEN
Put it in 4 wheel drive, 4 low and back up or go forward at low speed. Also do this under turning conditions to give the wheel joint (u joint) a lot of stress/torque. This should cause noise if the wheel joint is bad.
To check the wheel bearing, you can jack the front and spin the wheel and listen for a clicking sound in the wheel itself. You can also take the truck on the highway and listen for the same noise at speeds around 55-60 MPH. Make sure your not in 4 wheel drive while doing this
Old Jun 26, 2011 | 04:48 AM
  #25
S S0DEN's Avatar
S S0DEN
I have replaced my drivers side U Joint twice in 3 years, once when I did the wheel bearing and again yesterday. I had a light clicking sound that increased in volume as I increased in speed.
