Clicking from front end.
Old Jun 3, 2011 | 12:56 PM
EHS22's Avatar
EHS22
Default Clicking from front end.
I have noticed lately a clicking sound coming from the driver side part of the front end. I can only hear it with the windows down and it starts around 25mph when I'm braking coming to a stop. Does anyone know what this could be? Possibly a ball joint?
Old Jun 3, 2011 | 01:06 PM
Check your brakes. Inspect ALL front end parts for wear. Might be u-joint, or wheel bearing, so just something caught in the brakes.
Old Jun 3, 2011 | 03:24 PM
duggy's Avatar
duggy
its the hub bearing. costs about 100 bucks for the part.
Old Jun 3, 2011 | 03:26 PM
CappinHoff's Avatar
CappinHoff
Not always. I had the same sound and it was the u-joint.
Old Jun 3, 2011 | 04:08 PM
Kingsnap's Avatar
Kingsnap
I currently have a click when slowing down. I just identified that my shocks are junk and I need new ones. Maybe the same with you?
Old Jun 3, 2011 | 04:34 PM
RamSport97's Avatar
RamSport97
Make sure the lower shock mounts are torqued to 100 foot pounds and the tops are secure as well.
Old Jun 3, 2011 | 04:42 PM
jasonw's Avatar
jasonw
Site Moderator
Have to check the manual, but the tops IIRC are something around 40 ft lbs, and you are right about the bottoms, 100 or a little more.
When mine clicked at low speeds, especially when turning or over small bumps, it turned out to be u-joints AND ball-joints.
Old Jun 3, 2011 | 04:52 PM
RamSport97's Avatar
RamSport97
Yes sir.
2wd models 1994-2001:
Lower bolt: 100 foot pounds
Upper nut: 30 foot pounds
4wd models:
Lower bolt 1994-1997: 100 foot pounds
Lower bolt 1998-2001: 105 foot pounds
Upper Nut 1994-1997: 30 foot pounds
Upper Nut 1998-2001: 35 foot pounds
Old Jun 3, 2011 | 06:11 PM
Kwdog75's Avatar
Kwdog75
x2
U-Joint for sure.
Old Jun 3, 2011 | 07:00 PM
Kingsnap's Avatar
Kingsnap
To give a little more detail, mine only clicked when I would apply brake or going up a hill. I know the noise a axle joint can make. I have done mine and the ball joints. Mine started off as a rubbing sound, thought it was track bar. Did that, then ball joints because driver side upper was bad. Since winter is when the click started. Now I can put my finger through the coil and push on the center of the shock and push and I can hear the click faintly under a load I am thinking is make a snap/click sound.... (I have to have my window down to hear it too.) The the shaft has play, I did not install these so I have no idea the age or torque... I will be doing them tomorrow. I will update when I complete to be able to make sure my noise is completely gone.
But also if you have never done your axle joints that is probably it. I was just putting this out there.
