tranny gurus help
Old Jun 6, 2011 | 08:56 PM
BackwoodsRam's Avatar
BackwoodsRam
Default tranny gurus help
98 178xxx miles tranny rebuilt at 172xxxish
recently i lost tcc lock up, and i know its the tcc because i have a slight drop in rpms as i hit 4th gear. is there any way to tell if the problem is the torque converter it self or the lock up soleniod. i had tcc lock up one day and the next i didnt. i dont have any broken, clipped, torn or otherwise messed up wires. i dont have money to replace both right now but i need to fix this problem asap, because gas is killing me i have to run 26k rpms or more just to do the sppedlimit drivin back and forth to work
Old Jun 6, 2011 | 09:34 PM
If you are turnin' those kind of revs, you don't have fourth gear either.
Take the truck out someplace where you can hit 55mph, and there isn't much traffic. Start out from a dead stop, and accelerate at part throttle. Count the shifts. See how many you get. (I am going to guess, only two....)
Old Jun 6, 2011 | 09:39 PM
BackwoodsRam
i have from stop(also maually shiftin from 1 to 2 to drive) it shift from 1st to 2nd to 3rd and the a small drop as it goes to 4th. the last one is right around 55 and its only a small dropmaybe 1-200 rpms, it used to have that small drop and righ after itd drop down to 1500 or so rpms at 55 now it run 2k at 55, it only hits 26k or so when im doin 70ish
Old Jun 6, 2011 | 09:40 PM
BackwoodsRam
also im the only code im throwing is 0783 3-4 shift no rpm drop at lock up
Old Jun 6, 2011 | 09:41 PM
I wonder if you are getting TCC, but not fourth gear..... Might be as simple as replacing the solenoid pair for TCC, and Overdrive.
Old Jun 6, 2011 | 09:49 PM
BackwoodsRam
Everything ive been reading into says to do that, but it requires pulling the valve body, and im not gonna lie. Turning a wrench on my tranny scares me a little, how hard is it to pull the valvebody and change the soleniod set?
Old Jun 6, 2011 | 09:53 PM
There are a couple trans overhaul walkthrus linked in the FAQ section here. Check out J415's transmission thread, and just read over the parts about the valve body. If you have changed the fluid/filter in a trans before, you are already most of the way there. You need to pay attention to which bolts go where though, as it DOES matter. (I think there are pics in some of the walk thrus that point out where the odd ones go)
The real trick is, keep everything CLEAN, and don't lose the little ***** in the valve body, and be careful when you drop it, as other stuff comes with it. (couple pistons that should be obvious when you look up there, before the tranny fluid drips in your eye. )
You can do this.
Old Jun 6, 2011 | 09:56 PM
ghost4321's Avatar
ghost4321
Thats what it sounds like to me.
Old Jun 6, 2011 | 10:01 PM
UnregisteredUser's Avatar
UnregisteredUser
A drop that small is converter lockup, not overdrive. Overdrive engagement lowers engine RPM by 31% as the drive ratio goes from 1.00:1 to 0.69:1.
Old Jun 6, 2011 | 10:07 PM
BackwoodsRam
Thanks guys, i wont be able to change the soleniod set till next week but ill let yall know if it fixis the problem
