a/c problems and questions
hey guys, got a question for you. well when i bought my truck the a/c compressor was siezed, so i got a used one from a truck at work that a customer had abandoned and was being towed off.
i installed it last summer and didnt have the money to have it properly charged. it had oil in it and was running fine while on the belt.
the other day a friend of mine that works at my local advance does hvac for a living and puleed a vacuum on my a/c system. after he did that he threw a bit of refridgerant in it to check for leaks and what not and brought the pressure up to 70ish psi.
after he did that he had me start the truck and the compressor kicked on for a split second and then made a loud noise and spit a white mist out the front of it(which i can only guess was refridgerant).
so is my compressor toast, or is there something else wrong? i checked all the fuses and relays and they all are good. one suggestions or tips will be greatly sppreciated! thanks guys!
Blew the front seal out of the compressor. I don't know if that can be replaced easily or not...... My guess is, there was some moisture in the system, and over the year that it sat idle, things rusted. You would prolly be better off replacing the compressor......
i figured it was something stupid. i found another used one for 60 at one of the local JY's.
If the system it is hooked up to still has good pressure, you might be able to get away with that. If that system is empty as well, you might find yourself shopping for another compressor soon.
How much for a new one?
a new one is going for around 300 at my local advance 200~ on rock auto. i cant really afford that right now and the one at the JY is already removed from the truck, they have a 90 day warranty on everything they sell, so i will be fine if something happens.
