Best place to get 12v for accessories
Old Jun 8, 2011 | 02:21 PM
i mow grass's Avatar
i mow grass
Default Best place to get 12v for accessories
I am about to install a CB and some other interior accessories. I was just wondering where y'all get 12v for your stuff at. I was debating whether to get it off the cig plug (which would be switched) or whether I should run a power block/fuse block and put it underneath the back seat and have a relay off the ignition for it to be switched. If anyone has any advice or pics I would greatly appreciate them.
Old Jun 8, 2011 | 04:47 PM
99dodge318's Avatar
99dodge318
i ran my cb directly to the battery so i can still use it if i dont have the truck on, also i installed a overhead console out of a 97 and wired the map lights directly to the battery for the same reason.
my fogs are also wired to the battery, and i have the switch in the overhead console.
i bought some battery post wire taps from autozone for like $3, and a couple inline fuses.
for my gps i bought a add-a-fuse from autozone, pulled the radio fuse and installed it.
now my gps turns on/off with the key.
Old Jun 9, 2011 | 08:12 AM
i mow grass
Thanks, I saw your thread on your cb install. Where did you get that mount at? It is basically the same thing I was looking at making myself.
Old Jun 9, 2011 | 09:13 AM
99dodge318's Avatar
99dodge318
I bought it from genosgarage.com it was like $40
Old Jun 9, 2011 | 07:15 PM
TimSully88's Avatar
TimSully88
I have a Genos Garage Mount from a 2nd Gen for sale. Its on ebay and on CL.
http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_500wt_1156
Old Jun 12, 2011 | 11:22 PM
BigRedRam95's Avatar
BigRedRam95
I just paid for that.
Old Jun 13, 2011 | 06:42 AM
TimSully88's Avatar
TimSully88
Congrats on the win. I will be shipping it today. Enjoy it!
Old Jun 13, 2011 | 10:16 AM
BigRedRam95
Thanks i will letyou know when I get it. what kind of scanner were you running and where did you have your antenna?
Old Jun 13, 2011 | 10:32 AM
TimSully88's Avatar
TimSully88
I had a Uniden Bearcat with a glass mount that worked great. Also had a Cobra 19 mounted next to it with a Wilson 1000 mounted in the stake hole. That also worked well, good SWR readings made for great TX and RX.
