had a vacuum leak. fixed wow
Old Jul 7, 2011 | 12:18 PM
  #21
Does your 4x4 work?
Old Jul 7, 2011 | 01:42 PM
  #22
johnnybravo59's Avatar
johnnybravo59
Yessir, I followed the other line off that "T" and it ran to the vacuum junction with all the colors fir the four wheel drive stuff. All those lines are good
Old Jul 7, 2011 | 10:53 PM
  #23
Plug the broke off end then. If your vents work correctly, and your 4x4 works, that's it for vacuum operated stuff on the truck.
Old Jul 8, 2011 | 12:42 PM
  #24
zman17's Avatar
zman17
Retired Moderator - RIP
+1.... Maybe the previous owner had a vac gauge hooked up at one time.
Old Jul 8, 2011 | 01:38 PM
  #25
95RAM360's Avatar
95RAM360
hmmmmmmmmmmmmm.......*goes and checks truck*
Old Feb 27, 2018 | 10:58 AM
  #26
jfarris1991's Avatar
jfarris1991
Originally Posted by Jeffress77
Here is a photo of what it should look like. I drew the arrows to show that the vacuum line that runs from the spot that you taped off goes through the firewall next to the a/c evaporator core. Whoever replaced your dash broke that vacuum line (probably by pulling it through the firewall when they yanked the dash out, and they didn't replace it. That is why your defrosters don't work and why that line is open that you taped off.
I also have the same issue. can someone please repost this photo so that i can repair vacuum leak
