OK my truck is really starting to piss me off! I need some help....
Old Jun 11, 2011 | 01:30 AM
Aerogauge's Avatar
Aerogauge
Default OK my truck is really starting to **** me off! I need some help....
Ok so here is the deal, I had other threads to the other problems but lets just get it all here in this thread. 1996 Dodge Ram 1500 5.2L. It was stalling on me sometimes when I would stop at a light or something and then start right back up, I put a new IAC in it and cleaned the battery connections and replaced the spark plugs. After that it has not stalled out anymore at a stop.
Tonight, coming home from work I went to make a left turn at a intersection and was not stopped because the light was green, and it died on me while driving! so I am fighting this stupid thing trying to make it turn to not wreck into anything and trying to get it to brake to a stop, anyways I stopped, put it in park and restarted it and drove it home...
I need some good advice as to what is going on here with my truck... let me say what I know is wrong with it... it does have a SLOW antifreeze leak which I believe is coming from the water pump. It also is leaking oil slowly I believe from the rear main seal and oil pan gasket. Also the oil pressure gauge drops a little (not bottomed out but down some) sometimes but goes up as the RPM's increase, at idle the oil pressure gauge stays a little below the center mark and slightly moves down and up. And lastly, this one was posted in my other thread, lately its making a popping noise when I let off the gas or if I run the RPM's up near 3k and it shifts and the RPM's drop off and makes a pop sounds not loud but slight pop, sounds to be coming from behind the center of the dash...
Any help is appreciated, I am about fed up with this truck and really need to get it running right.
Old Jun 11, 2011 | 03:17 AM
96ramsport5.9's Avatar
96ramsport5.9
start off with the cheap stuff cap and rotor
Old Jun 11, 2011 | 03:50 AM
Aerogauge's Avatar
Aerogauge
any secret to accessing that easiest? It's nice and tucked away back in the back
Old Jun 11, 2011 | 05:41 AM
redneck_ram's Avatar
redneck_ram
not hard to get to at all. easiest way is to do it when fixing the plenum gasket. other than that i find it easiest to get in a comfortable spot laying on the motor(when its cooled down of course) and do it then. its not hard at all.
Old Jun 11, 2011 | 10:33 AM
I stole someone else's idea, and tossed a piece of plywood up there to lay on. That actually worked out fairly well.
Old Jun 11, 2011 | 05:23 PM
Aerogauge's Avatar
Aerogauge
Went to Autozone today, tested alternator and battery, alternator was good but battery bad so I bought a new battery and put it in, also new dist. Cap and rotor to put in maybe tomorrow, and also a new thermostat and gasket. You gotta unbolt the alternator and move it over to change the thermostat?
Old Jun 11, 2011 | 05:29 PM
aim4squirrels's Avatar
aim4squirrels
No, but it's a tighter fit if you don't. Remove the alt bracket and have a magnetic pickup tool handy for the t stat housing bolts.
If you grind the "front" tab off of the t stat housing, it's much easier to reinstall the housing without knocking out the bolts.
Old Jun 11, 2011 | 11:14 PM
Aerogauge's Avatar
Aerogauge
Argh, just gone attempting to do this, tried to get the alternator bracket out of the way but the front bolt wouldnt budge and I slightly stripped it. I am gonna take it to a mechanic, done messing with it
