in and out of overdive at higway speeds
Old Jun 11, 2011 | 03:01 AM
96ramsport5.9's Avatar
96ramsport5.9
Angry in and out of overdive at higway speeds
seems to go in and out of od on highway speeds but if im below 55 it will not hav a problem also it only happens first 10 min of seeing the freeway not right when i get on but like 3 min after.then after awhile prob goes away no codes with ob2 really starting to **** me off also was having rpm flucts about 100 to 200 increasements 10,000 miles on a new rebuild straight out of mopar factory.
Old Jun 11, 2011 | 10:45 AM
Sounds more like TCC than O/D..... check connections first.
Actually, if it is still under warranty.... take it in to where you had it installed.
Old Jun 11, 2011 | 11:52 PM
JSTMoto's Avatar
JSTMoto
I agree with HeyYou on this one. Kinda sounds like the truck is engaging and disengaging the Torque Converter lockup if it only varies a few hundred rpms.
This is typical of a failing Throttle Positioning Sensor. About $35 to fix.
-JT
Old Jun 12, 2011 | 10:06 AM
grizzlyalan's Avatar
grizzlyalan
I've had similar problems, irratic shifts into O/D and torque converter in and out of lockup. turned out to be the brake light switch out of adjustment. if the switch is out of adjustment it will kick you out of T/C lock up and out of O/D. The switch on my 96 2500 has a serrated tooth switch pin just depress the brake pedal and pull the pin out and release the pedal. Accidentaly lifting up the brake pedal or a worn bushing on the pedal pivot pin can cause this to happen .
Old Jun 16, 2011 | 12:17 AM
96ramsport5.9
well i know its not tcc unlocking cus i hit od off when it does that and rpm dont move brake switch i know its not that cuz i bypassed it. what else can it be vss or rf interferance first thing i replaced was tps also haha help me out
Old Jun 16, 2011 | 11:49 AM
generaljr's Avatar
generaljr
there is a chance your transmission is overheating, maybe debris of the new internals plugging the filter or something else
