nv4500 5 speed 2wheel change
Old Jun 11, 2011 | 10:15 PM
captainray's Avatar
captainray
Default nv4500 5 speed 2wheel change
I need to change my nv4500 2wd. can I use a 4500 from a v10 or diesel or do I have to get one from a 5.9
Old Jun 12, 2011 | 12:29 PM
pcfixerpro's Avatar
pcfixerpro
you will need to use your bell housing if getting from a v10 or diesel. Input shaft will be different between the two, and should be interchangeable. I would do that anyway so you know it will bolt up because I believe some spline changes did occur over the years. Not sure on the output end though. If the donor 4500 is from a 4wd, you will also need your stock tail housing. Other than that... should be about it. Good luck
Old Jun 12, 2011 | 02:03 PM
Is the trans output shaft the same length between 2 and 4 wheel drive?
