Governor Pressure Sensor Voltage?
Old Jun 14, 2011 | 11:36 PM
Not unless it was well and truly borked. Which I would think would be obvious on casual inspection.
Old Feb 1, 2020 | 05:24 PM
mechacon's Avatar
mechacon
Default Mauricio
Hallo I'm new to the Forum! I have a similar problem with a code P0783 shift 3-4 I found several problems like broken spring bad selenoid and bad transducer sensor! Changed all that and the code kept poping up! I ordered a reconditioned valve body changed it and then i seen that the hardness connection to it was all worned out! So i went to a wreking yard and changed it and now I get two diffrent codes P1763 and P1762 voltage to high or too low on the pressure sensor selenoid! I'm stuck here and any siggestions would help! Thank you all By the way this is on a Dodge Ram 1500 1998 5.9L
Last edited by mechacon; Feb 1, 2020 at 05:26 PM. Reason: Forgot to put year model of vehicle
Old Feb 2, 2020 | 09:35 AM
Check all your wiring from the trans to the PCM. Could be a bad connection.
Old Feb 2, 2020 | 01:30 PM
mechacon's Avatar
mechacon
Thank you i will do that! Do you think I need to change the entire wiring system? because all i did is cut the wires and connect them together with some wires connectors that you have to tightned them and then they snap together. I'm just thinking that the pcm is detecting the wires not being solid from the manufacture! I also checked the pressure sensor selenoid and it clicks and the ohms were 3.9 so i figured that is working properly!
Old Feb 2, 2020 | 01:31 PM
mechacon's Avatar
mechacon
Default Mauricio
Old Feb 2, 2020 | 02:12 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Where did you cut the wires? Soldering is the best way to connect wires, you could quick butt connectors in a pinch. I'm not understanding what type of connector you used
Old Feb 2, 2020 | 03:11 PM
mechacon's Avatar
mechacon
Default Mauricio
I didn't do the soldering but I cut the wires about 6 inches away from the hardness connection and i used some bullet splice connections! They snap really good but I'm not sure if that's the problem!
Old Feb 2, 2020 | 04:11 PM
Why did you cut the wires? If you have the correct parts, it should just plug right in. If it didn't, it's entirely possible that you have the incorrect sensors....
Old Feb 2, 2020 | 04:40 PM
mechacon's Avatar
mechacon
Default Mauricio
The locking parts were all worn out and the hardness wasn't secured and i thought at the moment that maybe that could be the reason for the code i was getting
Old Feb 2, 2020 | 05:55 PM
MoparFanatic21
Them bullet splice connectors I believe after part or is your issue. They are not a great connection.
