Governor Pressure Sensor Voltage?
Old Feb 2, 2020 | 06:18 PM
  #21
mechacon's Avatar
mechacon
Default Mauricio
I guess im going to go get me a good soldering tool and see how that goes! Thank you very much for the help I'll let you know how it goes! Thank you again
Old Feb 2, 2020 | 06:56 PM
  #22
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Before you do that, check the wires
Old Feb 2, 2020 | 07:29 PM
  #23
mechacon's Avatar
mechacon
Ok will do that!
Old Feb 2, 2020 | 11:06 PM
  #24
MoparFanatic21
Ok will do that!
If they prove not to be bad by checking resistance then move on
Old Feb 3, 2020 | 02:00 AM
  #25
mechacon's Avatar
mechacon
Default Mauricio
Ok will do!
Old Feb 3, 2020 | 03:01 AM
  #26
MoparFanatic21
I will say this having them connectors (commonly called scotch lok connectors) will cause the wires to corrode as they are not sealed. So eventually fix them
Old Feb 3, 2020 | 12:57 PM
  #27
mechacon's Avatar
mechacon
Default Mauricio
I have to get it fixed one way or the other! I can't get it smogged until i clear the codes all together! Even though the truck runs without any signs of problems!
Old Feb 3, 2020 | 01:24 PM
  #28
MoparFanatic21
Download the FSM from the the FAQ section. Wiring is in section 8W then test the wires to see if they see getting the right voltage. Usually that code indicates a wiring issue.
Old Feb 3, 2020 | 01:50 PM
  #29
mechacon's Avatar
mechacon
Default Mauricio
Ok I'll be checking on that!
Old Feb 3, 2020 | 04:17 PM
  #30
MoparFanatic21
Report back
