misfires?
Old Jun 14, 2011 | 08:37 AM
meanwhitemopar's Avatar
meanwhitemopar
Default misfires?
So I got the new trans in. Motor runs, but does not run right.. sits at idel at 600 and fluxs to 750ish and back and forth.
In park, hit the gas, floored seems like rev limiyer at like 3k
If I hit gas to much while driving, seems it back fires..
Old Jun 14, 2011 | 08:45 AM
Did you smack up the crank sensor when installing the trans? Might wanna have a look at it.
Old Jun 14, 2011 | 09:30 AM
meanwhitemopar
What would it do if its messed up?
Old Jun 14, 2011 | 09:41 AM
Give incorrect readings..... or, work intermittently, or, stop working altogether..... I would suggest at the very least pulling it out, and having a look. Damaging the sensor is really common when pulling the engine or trans with it still in place.
Old Jun 14, 2011 | 10:14 AM
meanwhitemopar
I will check that
Old Jun 14, 2011 | 10:20 AM
meanwhitemopar
I'm pretty sure I may have bent that.. but also i may have bent or scratched the flex plate holds, I was tightening the flex plate bolts by wedging a screw driver in those holes
Old Jun 14, 2011 | 10:26 AM
meanwhitemopar
Holes*
Old Jun 14, 2011 | 10:27 AM
I don't think you can damage the holes that much, so as to be unreadable..... Tweaking the sensor however, WILL cause ya some trouble.
Old Jun 14, 2011 | 10:51 AM
meanwhitemopar
Ok, ill check that here either tonight or tomorrow
Old Jun 15, 2011 | 08:32 AM
meanwhitemopar
Ok.. I changed the tps and iac, and it made everything worse, I was ideling at about 2300 lol.
