nv4500 behind 5.9 gaser?
Old Jun 14, 2011 | 03:25 PM
mj23polaris's Avatar
mj23polaris
Default nv4500 behind 5.9 gaser?
so my 46re slips, jumps, wines once in a wile, and just acts retarded...
so i want a stick, what needs to be done for me to put a nv4500 under my 2001 Ram 2500 4x4 gaser
Old Jun 14, 2011 | 04:14 PM
Pedal assembly.
Clutch Linkage.
Bell housing.
Flywheel.
trans for 4wd.
since you already have a 241 t-case, trans should fit on that end.
Also, to make it 'right', you would need the wiring harness, clutch safety switch, etc from a manual trans truck, and then the PCM, or, reprogram yours for the manual. (otherwise, you will constantly be getting a CEL for things that aren't there any more.)
Old Jun 15, 2011 | 12:36 AM
matt72991's Avatar
matt72991
i dont know if the transfer case will work. i thought the manuals and autos used different transfer cases...???? not 100% but you will love the manual alot more power.
Old Jun 15, 2011 | 10:41 AM
I seem to remember something about different spline counts on the input for the t-case, but, I am not 100% sure on that..... would bear some additional investigation.
Old Jun 17, 2011 | 10:04 AM
matt72991's Avatar
matt72991
i did some digging around my computer and this. i had to replace a t case in a 96 half ton and needed to know what would work. but here ya go.
RAM 2500 PICKUP 1997-94 23 spline front input 32 spline rear slip output, 1.375 O.D., w/P.T.O. 1.750" speedo hole, 1.550" ex NP241DHD
RAM 2500 PICKUP 1997-94 23 spline front input, 32 spline rear slip output, 1.375 O.D., w/P.T.O., w/1.750" speedo hole, .840" NP241DHD
RAM 2500 PICKUP 1997-94 23 spline input, 32 spline slip rear, flat circular front output, w/speedo hole, 1.550" exposed inpu NP241DLD
RAM 2500 PICKUP 1997-94 29 spline front input 32 spline rear slip output, 1.375 O.D., w/P.T.O. 1.750" speedo hole, 1.550" ex NP241DHD
RAM 2500 PICKUP 1997-94 29 spline front input, 32 spline slip rear, flat circular front output yoke, w/speedo hole, 1.550" e NP241DLD
RAM 1500 PICKUP 1997-96 23 spline input, 32 spline rear slip output, w/1.750" speedo hole, flat circular front output yoke, NP231D
RAM 1500 PICKUP 1997-94 23 spline front input, 32 rear slip output, w/speedo hole, 1.750" flat circular front output yoke, 1 NP231D
