Rear Brake Problems
Old Jun 14, 2011 | 09:20 PM
diehardjohndeer's Avatar
diehardjohndeer
Question Rear Brake Problems
I adjust them to where they hold but then they drag.And when I back them off just so they don't drag they don't hold.
I put new drums and shoes on both sides.
I need to get this fixed soon because I'm taking a 466 JD engine to Bedford PA over the 4th.I really don't wanna drive 8 hrs with my brakes like this.
Any help is greatly appreciated!
Old Jun 14, 2011 | 09:40 PM
crazzywolfie's Avatar
crazzywolfie
just make sure your auto adjusters work good and let them tighten them self. a little bit of drag is normal.
Old Jun 14, 2011 | 09:59 PM
dhvaughan's Avatar
dhvaughan
how much drag are we talking about. a whole lot or just a tick tick tick. a little drag tick is normal.
i adjust them by tightening them up where the wheel won't turn, and then backing it off to where it turns freely, even if its still got a tick.
Old Jun 14, 2011 | 10:29 PM
diehardjohndeer
it drags enough that they get hot and it pulls the engine down
Old Jun 14, 2011 | 11:30 PM
Back them off a notch or two. You should be able to hear the friction material in contact with the drum, but, not to the point where they get difficult to turn. Are your drums out of round?
Old Jun 15, 2011 | 10:46 AM
diehardjohndeer
They shouldn't be since I just put brand new ones on it
Old Jun 15, 2011 | 10:53 AM
merc225hp's Avatar
merc225hp
Not to q your mech ability but did you put the new shoes on right?
Old Jun 15, 2011 | 10:56 AM
Just because they are new, does not necessarily imply they aren't out of round. I turn even the new ones, as a matter of course. I don't like come-backs.
Not to q your mech ability but did you put the new shoes on right? there are two diff shoes and they must be installed the right way.
Valid point. Didn't even think of this one.
Make sure you install the shoe with the SMALL pad area on the front side of the drum.
Old Jun 15, 2011 | 10:58 AM
merc225hp's Avatar
merc225hp
Thanks Heyyou I guess i should have said watch way they go.
Old Jun 15, 2011 | 07:15 PM
seabass202's Avatar
seabass202
through what method are you engaging the brakes when they don't hold? brake peddle or parking brake?
